2021.03.07 "Extra" Pic
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/ArUQ
I remember using a spring tooth harrow and a
cultivator similar to that with wheels, pull the rope to
raise, pyorrhoea same rope to drop the cultivator
teeth into the dirt. Always have that rope in hand
when approaching a wet spot, and get the cultivator
up before the tractor goes down. Some great
childhood memories of working dirt for my dad in
the spring.
We had what dad said were weed destroyers looked just like those spring tooths only we had just 1 lever for the whole drag. We used to put 2 together with an evener and pulled them with the Cat in early years then with the 830 case and then one with the disc on bigger tractors some. Finally got a field cultivator. To much work moving them with ground spread out to haul down the road. Had to load or take with loader then set down.
We had 2 sections of spring tooth, but 1 4 foot section was all the 8N wanted. They'll tear up sod, but leaves it all on the top. Plow worked better.
