2022.02.16 "Extra" Pic
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/WrrJ1
I had that loader on my H, the cylinders are actually two stage, there is a smaller cylinder inside the main out side one. It will lift higher then you would want to lift anything with a narrow front. Even with the low pressure hydraulic pressure of the belly pump it would lift more weight then anyone should have on an H narrow front. I just had a steel bar between the bucket hinge points, it would lift a big block Chevrolet with ease.
There are extra lift links, as well as the actual loader not in the picture. Loader pivots on rear axles. All you're seeing here are the lifting mechanism. And yes, the loader has a whole lots of lift and lifting ability. I've used mine to lift bucket filling rocks, and used to lift shingles to the roof. Wife has used ours to lift me to the top of a huge load of shocked oats, to put a tarp over it. That was a scary ride. Tarp blew off and she had to lift me a second time.
