2023.05.13 Tractor Pic
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/n4BQa
Was kind of thinking the same thing. The backside of the lugs are not very thick. And the rim they are bolted to is sure not very wide either.
I have driven tractors on steel, but not an Oliver. Always wondered how bad this style of Oliver wheel sunk into to the ground. Would likely have to get off of the sod, and into mud of soft dirt (worked ground) to find out.
Skeleton steel is bad about sinking in anyways. But boy, there really isn't much to keep these from just going right on down. Deere lugs for example, had a really thick backside. IHC lugs for the letter series were bolted on in staggered pairs (had meat in between lugs that met up with the ground surface). Even in between the paired lugs, was a good 2 inch thick rim.
About the only thing stopping these is the lugs that are about the 4th or 5th one up from the bottom that are starting to hit the ground more horizontally. And they'll only slow the sinking then if you have already sank in that far.
I'd sure like to see how these would fare myself.
