Wes Wilkens
Several days ago I posted a question concerning the three point on my 2030 that won't raise immediately when I move the lever. It works correctly some of the time but usually not. However, if I slightly move the hydraulic lever (svc) right after I've moved the 3 pt lever, it will raise immediately. Something is up and I'm not nearly familiar enough with the system to properly diagnose it. I do have the service manual though and can follow through the hydraulic circuits.
At the time I posted my question, Tx Jim responded and since I was traveling, I wasn't able to answer his questions. I'd like to do that now if he's still interested in helping me.
First, I have not checked the standby pressure. I think there is a procedure in the manual to do that and I will do that as soon as I can find the time. I will check today to see where I had left the L/D setting and get back here with the answer. You mention to look in the filler for spraying oil when the engine is running. What does that mean if there is or isn't oil spraying? I will do that this morning too.
I do appreciate your help Jim.
Thanks,
Wes
Thanks,
Wes
