2040 load shaft seal
Hydraulic oil is leaking around the load shaft(where the hitch arms attach) and the O rings and plastic washer need replacing.What is the best way to replace them?There must be trick getting the washer in the groove without damaging it. Thanks for your help.
Not a bad job,gives you a chance to get stuff out that dont come with a fluid change sometimes also.My luck is almost always been that I have to buy the shaft also
