206D experts
molinegb
Have 206D that won't start. I have fuel at injectors. Energy cells have been removed and cleaned. Appears to have decent compression. No exhaust even with ether. It will snort a bit with ether. Has been sitting for several years. Usually a bad motor will give uneven running or lots of white smoke.
You say you have fuel to the injectors but do you mean that there is fuel at the line or do you know if the actual inj is spraying fuel? I would pull a injector hook the line back up and crank the engine and watch to see if it sprays if it doesn't you probably have pump problems.. But almost all engines if in good mechanical shape will run on ether so it may have other problems like a broken camshaft but let's hope not and good luck
When energy cells removed it sprays out. Removed pump. Appears pump timing mark in window is 1 tooth out to mark on pump shaft.
