2090 case tractor tire size
Marcel2
I have a case 2090 with 20.8 x 34 tires that need to replaced. The tires have a cast middle. What is the most common size on the 2090 tractors? What would be the best size for this tractor, keeping in mind i live in Northern Saskatchewan Canada? thanks? are the 20.8 x 34 available.
Most 2090 and 2290's I've seen usually had 18.4-38 duals, either factory or clamp-ons. 20.8-34's should be available, seen them dualed up on 4690 4wd's.
Here in central NY, 20-2290s were ordered and sold with 20.8x38 rears, a few with 18.4x38s if bought to plant with, or if older narrower plows were being pulled. We used to order some 9-1070s with 20.8x34s and really liked that combination. Most had 18.4x38s.
Loren
thanks for the replys, I talked to a friend who suggested 18.4 duals would get the most rubber on the ground. I priced out 20.8 x 34 new with new tubes $4100. thanks for your help. as it stands now i will just keep spinning with the wore out tires until something drastic happens (flat tire)
Marcel
