I have had my 2090 for 18 years and have never been able to get to the bottom of a hydraulic issue. When the tractor leans to the right and I hit a bump the hydraulic pump sucks air. If I run the oil level 1" high on the dipstick it helps, but just takes a big bump. Last time I had the transmission all apart I looked at the oil suction to the charge pump, and it looked to me like that is all well below the oil level. If it was a leak after the charge pump leaning to one side, or bumps should not effect it. I try to keep the oil level high enough as not to damage the pump, but it is a PITA because the brake cylinders always have air in them. I have seen several 90, and 94 series tractors that have the transmission dipstick twisted about 15 turns. Is that to fix this problem? Has anyone else had this issue? Is there a fix?
