Paul for Wi
Was using the 2096 with a heavy mounted 3pt load (Dyna-Drive) last week and when I went to lift it at the end of the field it started to come up and then just kind of dropped down- but did not drop all the way to release the pressure from the pins, I had to lift up the implement to unhook it. When it was still hooked up when I tried to lift up, it would try to raise it a little and pull the motor down some but not raise more than an inch or two- never pick the weight off the ground.
I tried tapping on the load / height sensing tube right next to the cable / control arm underneath the differential because I remembered that seemed to make the 3pt work on an older 2090 we had- something about the piston inside side being worn and getting stuck in there, this did not seem to do any thing with this 2096 though and since it seems to try to lift some I am thinking something actually may be broken.
The other functions on the tractor still seem to work OK although I just drove it back to the yard and have not used it beyond that. I am not seeing anything leaking and the control cable seems to work like it should underneath. When unhooked I raised the 3pt up all the way and now it will not go down.
Does any one have an idea what the problem might be? Still hoping for a simple fix - hopefully the casting is not broken.
Thanks for any suggestions.
