2096 shutdown
My dad has 2096, hooked the baler on and shut it off, put twine in and the tractor started acting up. With the override switch in the up position (enabled) the engine with turn over but not fire(no power to the solenoid). With the switch down (disabled) it will start and run and the dash (electronic) is showing all is well. When the switch is put to the up position the engine stops immediately, went through the troubleshooting for the pressure switches on the engine, they are good. going to check the transmission switches in the morning. I thought it would run for 30 seconds then shut down if something was wrong in that circuit. What am I missing, the switch?
I found most of my electrical problems in these is in the plug at the firewall.trans switchs should not effect the running,oil or water should have a red light on the dash along w/buzzer.
