Tried to replace load control shaft 2120. Supplier sent a unpolished shaft that was 9/10 of and inch instead of the .877 that was in it. They also sent JD #R1225R O ring which is to big. Does anyone know if the R460R would be correct. No size specs on web sites. It should be slightly smaller than R1225R and fit tight around the T22095 sealing washer. How flex able is the sealing washer, did I ruin it by trying the 9. shaft in it or is it elastic enough to recover.
From the online parts books it appears a couple different load shafts were used. One being called heavy duty. It appears the bushings, O-rings, seals etc. were different between them. You should talk with the supplier and review the dimensions of your old shaft and sealing components, sounds like you may have the regular shaft and they sent the heavy duty one.
The parts page I looked at. Read the illustrations available notes. Also notice there are a couple choices for some of the same item key numbers in the shaft area.
https://partscatalog.deere.com/jdrc/sidebyside/equipment/82654/referrer/navigation/pgId/250913
