22' bumper pull stock trailer?
kyplowboy
Any one ever pull a 22' bumper pull stock trailer? There is one come'n up at auction close to here. Never seen a bumper pull that big. Pic looks fair but don't say how heavy the axles are. It has the big square fenders like some of the older gn trailers around here.
Dave
I'd maybe try it behind a 1.5 or 2 T with out a bed so it would hitch close to the rear axel.
Be alot of toung waight for most trucks. M2C
Thats pretty much what I thought when I seen it. I have a f350 duely that is pushing 20 years old. Only thing that has ever squated it on the hitch was a 14' cultimulcher I pulled home from an auction one time, but that trailer loaded might be more than she would want.
A friend one mine has one he pulls behind his 1 ton. I work on it off and on his goats like the wiring. Takes a heavy truck and good brakes both on the truck and trailer to pull one loaded. Also in heavy winds it can be a lot of fun pulling on NOT. Empry a 3/4 ton will do ok but loaded nothing least then a 1 ton and that can even push one of them if it is full of say 5-10 2000lbs steers
Depends on how far back the axles are set as to how much tounge weight you would have and how the weight was distributed when loaded. Is it set up like those double axle 25 ton pintle hitch equipment trailers?, most have high strength frames and the axles are set way back on the frame so their is minimal hitch weight on the truck. It takes more truck to stop it than pull it.
I got all I want behind my 3/4 ton with my 16ft and 4 market steers hooked on the bumper. I'd look for a goose-neck if you need a trailer that size. I have a fifth wheel on my truck too and I feel alot more comvertable with a heavy load hooked to that as opposed to the bumper.
