2240 Electrical Question
cizmas
The wiring diagram from the Technical Manual for 2040 and 2240 (from 01Nov1980) shows nothing connected to the G terminal of the key switch. In the description of the key switch, however, it is said that on start position, there is continuity between the G terminal of the key switch and the ground. How can this be achieved if there is no wire connected to the G terminal?
Thank you,
Paul
The body of the switch provides the "ground", provided it it cleanly attached to a grounded metal panel.
What is then the purpose of the G terminal on the key switch? - please see Fig. 7 attached. Should the G terminal be attached to anything?
The Technical Manuals (please see also the 1975 manual for 2240, which explains a bit clearer the "start position") state that in the "start position" there is continuity between the G terminal and ground. I would understand from this that there should be no continuity between the G terminal and ground when not in "start position".
If the body of the switch provides the continuity to ground, this continuity would be always, not only in the "start position".
That ign switch AR58126 fits a very long list of different JD tractors therefore the "G" post could be utilized for a different model tractor than your 2240.
970 - 1020 Tractor - 16May11
971 - 2020 Tractor - 16May11
972 - JD300 Series Tractors - 02Nov06
973 - JD400 Series Tractors - 02Nov06
1088 - 4520 Tractor - 16May11
1109 - JD480 Forklift - 06Nov06
1115 - 3020 Row-Crop Tractor (S.N. 123,000- ) - 16May11
1116 - 4000 and 4020 (s.n. 201,000- ) Tractors - 20May11
1121 - 1520 Tractor - 16May11
1124 - 860 and 860A Elevating Scrapers - 02Nov06
1128 - JD500 Series B Backhoe Loader - 02Nov06
1142 - 690 and 690A Excavators - 03Nov06
1145 - 2520 Tractor - 16May11
1153 - JD760 Series A Tractor - 02Nov06
1155 - JD700 Series A Tractor - 31Jul06
1156 - 5020 (S.N. 025,000- ) Tractor - 16May11
1176 - JD500-A (123114-152141) Backhoe Loader - 06Jul06
1228 - 4320 Tractor - 16May11
1229 - 4620 Tractor - 16May11
1236 - 7020 Tractor (Worldwide Edition) - 13Mar14
1239 - 500C Backhoe Loader - 07Nov06
1240 - 510 Backhoe Loader - 29Aug06
1241 - JD301 Tractor - 03Nov06
1242 - JD401 Tractor - 11Dec08
1289 - 2030 Tractor - 16May11
1290 - 6030 Tractor - 16May11
1291 - 7520 Tractor (Worldwide Edition) - 17Apr14
1293 - 4030 Tractor - 16May11
1294 - 4230 Tractor - 16May11
1295 - 4430 Tractor - 16May11
1296 - 4630 Tractor - 17May11
1367 - 2250 and 2270 Hydrostatic Drive Windrowers - 11May11
1370 - 690B Excavator - 06Nov06
1401 - 2630 Tractor - 16May11
1417 - 4219DF OEM Engine and Accessories (Dubuque) - 28Feb13
1418 - 6329D OEM Engine and Accessories - 29Oct14
1428 - 300B Loader and Backhoe Loader - 26Mar08
1429 - 301A Tractor and Loader - 03Nov06
1430 - 401B Tractor and Loader - 03Nov06
1431 - 401C Loader and Backhoe Loader - 19Jul05
1432 - 302 Tractor and Loader - 06Nov06
1433 - 302A Loader and Backhoe Loader - 16Jun06
1435 - JD380 Forklift - 06Nov06
1436 - JD480A and JD480B Forklifts - 07Nov06
1457 - 9900 Cotton Picker - 18May11
1469 - 4276 OEM Engines and Accessories (Dubuque) - 28Feb13
1471 - 6414D and 6414T OEM Engines and Accessories - 22Aug14
1485 - 8430 Tractor (1974-1981) (Worldwide Edition) - 14Mar14
1486 - 8630 Tractor (Worldwide Edition) - 17Apr14
1504 - 770 and 770 (Automatic Blade Control System) Motor Graders - 29Aug06
1519 - 670 and 670 (Automatic Blade Control System) Graders - 06Nov06
1520 - 762 Elevating Scraper - 21Oct08
1538 - 2440 ( -340999) Tractor - 16May11
1539 - 2640 (s.n.-340,999) Tractor - 16May11
1563 - 6619AF, 6619TF-01 OEM Engines and Accessories (Waterloo) - 27Jun14
1572 - 484 Cotton Stripper - 02Jun11
1580 - 693B Feller Buncher (Canada) - 09Apr04
1581 - 693B Feller Buncher (USA) - 06Nov06
1592 - 860B Elevating Scraper - 21Oct08
1604 - 2280 Hydrostatic Drive Windrower - 11May11
1616 - 890 Excavator - 21Oct08
1620 - 670A, 672A, and 670A, 672A (Automatic Blade Control System) Graders - 24Apr08
1621 - 770A/770AH and 772A/772AH (Automatic Blade Control System) Mo tor Graders - 06May10
1721 - 6466D,T,A (s.n. 067685- ) OEM Engines and Accessories - 28Feb13
1760 - 2440 (341000- ) Tractor - 16May11
1761 - 2640 (s.n. 341,000- ) Tractor - 16May11
1762 - 2940 Tractor - 16May11 ( FR DE )
1763 - 2040 Utility Tractor (350000- ) - 16May11
1764 - 2240 (350000- ) Tractor - 16May11
1776 - 8955T and 8955A OEM Engines and Accessories - 22Aug14
1846 - 480C Forklift - 05Aug04
1851 - 990 Excavator - 21Oct08
1874 - 8850 Tractor (Worldwide Edition) - 27Jun14
1875 - 8450, 8650 Tractors (Worldwide Edition) - 14Mar14
1882 - 890A Excavator - 06Nov06
1883 - 401D Tractor - 29Sep05
1898 - 4040, 4240 and 4440 Tractors (North American Edition) - 16May11 ( FR DE )
1899 - 4640 and 4840 Tractors - 16May11
1901 - 4050, 4250 and 4450 Tractors (Engine:6466D,6466T,6359T)(Worldwide Edition) - 16Dec14 ( FR DE )
1902 - 4650 and 4850 Tractors (Worldwide Edition) - 14Mar14 ( FR DE )
1903 - 8440 and 8640 Tractors - 27Jun14
1907 - 2320 and 2420 Windrowers - 11May11
2011 - 3430 and 3830 Self-Propelled Windrowers - 11May11
2054 - 655, 755, 756, 855 and 856 Compact Utility Tractors - 13Dec14 ( FR DE IT ES SV )
2057 - 330 Lawn and Garden Tractor - 13Oct03
2075 - F915 Front Mower - 15Mar14 ( FR DE IT ES SV )
2139 - 332 Lawn and Garden Tractor - 13Oct03
2148 - F912 Front Mowers - 15Dec14
2149 - 322 Lawn and Garden Tractor - 30Aug01
2182 - 6076 (s.n. -499999) OEM Engines (Waterloo) - 28Feb13
2224 - 8560, 8760, 8960 Tractors (Worldwide Edition) - 15Dec14
2249 - 4055, 4255 and 4455 Tractors (Worldwide Edition) - 27Jun14 ( FR DE IT ES SV )
2263 - 955 Compact Utility Tractor - 19May14 ( FR DE IT ES SV )
2270 - 4555, 4755, 4955 Tractors (North American Edition) - 16Dec14 ( FR DE IT ES SV )
2276 - 2243 Gas Professional Greens Mower - 31May13 ( FR DE IT ES SV )
2294 - 6059 and 6068 OEM Engines(Dubuque)(S.N. -699999) - 28Feb13
2298 - 4239D and 4239T OEM Engines and Accessories (Dubuque) - 27Jun14
2299 - 6359D and 6359T OEM Engines and Accessories (T0-Dubuque) - 27Jun14
2305 - 4039 and 4045 OEM Engines (Dubuque - T0)(ESN -699,999) - 10Jan14
2334 - 4560, 4760 and 4960 Tractors (Worldwide Edition) - 16Dec14 ( FR DE IT ES SV )
2337 - 4039DFM01 and 4045TFM01 Marine Engines and Accessories (Dubuque) - 10Jan14
2359 - 2653 Professional Utility Mower - 12Dec14 ( FR DE IT ES SV )
2372 - 8570, 8770, 8870 and 8970 Tractors (Worldwide Edition) - 15Nov14 ( FR ES )
2380 - 6076 OEM Engines and Accessories (Waterloo) - 22Aug14
2385 - 6101AF010, 6101HF010 OEM Engines - 28Feb13
2402 - 2243 Professional Diesel Greens Mower - 12Dec14 ( FR DE IT ES SV )
2423 - 6076AFM30 Marine Engine and Accessories (Waterloo) (ESN 500000 - ) - 28Feb13
2514 - 2653A Diesel Professional Utility Mower - 14Nov14 ( FR DE IT ES SV )
2521 - PowerTech 4.5L 4045TF151 Engine (Worldwide Edition) - 07Jul14 ( FR DE IT ES SV )
2522 - PowerTech 6.8L 6068TF250 OEM Engine - 02Dec14 ( FR DE IT ES SV )
2527 - 8.1L PowerTech OEM Engine (6081AF001)(ESN -199999) Worldwide Edition - 04Aug14 ( FR DE IT ES SV )
2581 - PowerTech 12.5L 6125AT801 Engine - 16Sep14 ( FR DE IT ES SV )
2731 - PowerTech 12.5L (6125AFM01) Marine Engine (Waterloo) - 02Oct12 ( FR DE IT ES SV )
2820 - 8.1L (6081AFM01) PowerTech Marine Engine - 28Feb13 ( FR DE IT ES SV )
2875 - PowerTech 12.5L 6125HF070 OEM Engine (ESN 030000-)(Waterloo) - 27Feb14 ( FR DE IT ES SV )
2876 - 8.1L (6081HF070) PowerTech OEM Engine (S.N. 200000-) - 31Mar14 ( FR DE IT PT ES SV )
3153 - 4239D, 4239T, 4329A (3.9L) OEM Engines (Saran) - 01Jul14
3154 - 6359 OEM Engine and Accessories (CD-Saran) - 01Jul14
3178 - 3179DF/3179TF OEM Engines, Accessories and Repower (Saran) - 18Apr13 ( FR DE IT ES SV )
3191 - 4039 Repower and OEM Engines (Saran) - 30Sep14
3192 - 6059 OEM Engine and 6059DF092 Repower (100000-499999) - 26Aug14 ( FR DE IT ES SV )
3228 - Engine Accessories for 3029, 4045 and 6068 PowerTech Engines - 10Oct11
4127 - 3030, 3130 Tractors - 12May11 ( FR DE IT ES SV )
4132 - 830 Utility Tractor (North American Version) - 16May11
4133 - 1530 Tractor - 16May11
4143 - 1830, 2030, 2130 Tractors - 12May11 ( FR DE IT ES SV )
4150 - 2040 Utility Tractor ( -349999) - 16May11
4151 - 2240 ( -349999) Tractor - 16May11
4152 - 1020, 1120 Tractors - 12May11 ( FR DE IT ES SV )
4154 - 830, 930 Tractors (European Edition) - 12May11 ( FR DE IT ES SV )
4155 - 1030, 1130, 1630 Tractors - 12May11 ( FR DE IT ES SV )
4160 - 2840 Tractor - 16May11
4163 - 820, 920 Tractors - 12May11 ( FR DE IT ES SV )
4165 - 4040, 4240, 4440 Tractors (European Edition) - 12May11 ( FR DE IT ES SV )
4172 - 940, 1040, 1140 Tractors (European Edition) - 11Jun14 ( FR DE IT ES SV )
4173 - 1640, 1840, 2040 Tractors ( -429999) European Edition - 11Jun14 ( FR DE IT ES SV )
4174 - 2040S, 2140 Tractors ( -429999) European Edition - 11Jun14 ( FR DE IT ES SV )
4175 - 3040, 3140 Tractors ( -429999) European Edition - 11Jun14 ( FR DE IT ES SV )
4182 - 2150 and 2255 Tractors (North American Edition) - 11Jun14
4183 - 4040S, 4240S Tractors - 12May11 ( FR DE IT ES SV )
4184 - 1640, 2040, 2040S Tractors (430000- ) - 25Jul14 ( FR DE IT ES SV )
4185 - 2140 Tractor (430000- ) - 11Jun14 ( FR DE IT ES SV )
4186 - 3040, 3140 Tractors (430000- ) - 11Jun14 ( FR DE IT ES SV )
4187 - 2350 and 2550 Tractors (North American Edition) - 11Jun14
4188 - 2750 Tractor (North American Edition) - 11Jun14
4189 - 2950 Tractor (North American Edition) - 25Jul14
4207 - 3150 Tractor (North American Edition) - 12Dec13
4208 - 4350 Tractor - 12May11 ( FR DE IT ES SV )
4209 - 3050, 3350 Tractors (European Edition) - 11Dec14 ( FR DE IT ES SV )
4210 - 2650, 2650N, 2850 Tractors (Synchro-Transmission)(European Edition) - 11Dec14 ( FR DE IT ES SV )
4211 - 2250, 2450 Tractors (Synchro-Transmission)(European Edition) - 11Dec14 ( FR DE IT ES SV )
4212 - 1550, 1750, 1850, 1850N Tractors (European Edition) - 11Dec14 ( FR DE IT ES SV )
4214 - 2955 Tractor (s.n. -767516) North American Edition - 11Dec14
4215 - 2755 (GPT) and 2855N Tractors (North American Edition) - 11Dec14
4216 - 2355 and 2555 General Purpose Tractors (North American Edition) - 11Dec14
4217 - 2155 and 2355N Tractors (North American Edition) - 11Dec14
4223 - 2250, 2450, 2650 Tractors (Collar Shift Transmission) (European Edition) - 11Dec14 ( FR DE IT ES SV )
4224 - 1950, 1950N Tractors (European Editon) - 11Dec14 ( FR DE IT ES SV )
4226 - 3155 Tractor (North American Edition) - 11Dec14 ( FR DE ES )
4246 - 3055, 3255 Tractors (North American Edition) - 11Dec14 ( FR DE ES )
4496 - W210 Combine (China Edition) - 16Dec14 ( ZH RU )
6047 - 4455 Tractor (Manufactured in Mexico) - 01Jul11 ( ES )
6048 - 2755 Tractor (with Turbo) - 10Jul08
7055 - TRACTORS 2141,2541,2941 - 30Aug01 ( FR DE IT ES SV )
7057 - TRACTOR 3141,3641 - 30Aug01 ( FR DE IT ES SV )
7058 - TRACTORS 1641,1641F - 30Aug01 ( FR DE IT ES SV )
7063 - TRACTORS 2251,2251N,2351 - 30Aug01 ( FR DE IT ES SV )
7064 - TRACTOR 2651,2951 - 30Aug01 ( FR DE IT ES SV )
7065 - TRACTOR 3351,3651 - 02Dec02 ( FR DE IT ES SV )
8406 - PowerTech 8.1L (6081TF001) OEM Engine (ESN -199999)(Waterloo) - 29Sep14 ( FR DE IT ES SV )
8407 - PowerTech 8.1L (6081HF001) OEM Engine (ESN -199999)(Waterloo) - 06Aug14 ( FR DE IT ES SV )
8408 - 6090HFC95 Diesel OEM Industrial Engine (Interim Tier 4) - 06Aug14 ( FR DE IT ES SV )
8409 - 6090HFG95 Diesel OEM Generator Set Engines (Interim Tier 4) - 30Jul14 ( FR DE IT ES SV )
8411 - PowerTech 4.5L 4045DF120 Engine (Worldwide Edition) - 06Aug14 ( FR DE IT ES SV )
8412 - PowerTech 4.5L 4045DF150 Engine (Worldwide Edition) - 06Aug14 ( ZH FR DE IT ES SV )
8415 - PowerTech E 9.0L 6090HFC94 OEM Engine (IT4) - 07Aug14 ( FR DE IT ES SV )
8416 - PowerTech 4.5L 4045HF120 Engine (Worldwide Edition) - 21Aug14 ( FR DE IT ES SV )
8417 - PowerTech 4.5L 4045HF150 Engine (Worldwide Edition) - 17Sep14 ( FR DE IT ES SV )
8418 - PowerTech 4.5L 4045TF120 Engine (Worldwide Edition) - 07Aug14 ( FR DE IT ES SV )
8419 - PowerTech 4.5L 4045TF150 Engine (Worldwide Edition) - 08Aug14 ( FR DE IT ES SV )
8420 - PowerTech 4.5L 4045TF220 Engine (Worldwide Edition) - 08Aug14 ( FR DE IT ES SV )
8421 - PowerTech 4.5L 4045TF250 Engine (Worldwide Edition) - 08Aug14 ( FR DE IT ES SV )
8423 - PowerTech 6.8L 6068DF150 Engine - 11Aug14 ( FR DE IT ES SV )
8424 - PowerTech 6.8L (6068HF120) Engine - 11Aug14 ( FR DE IT ES SV )
8425 - PowerTech 6.8L (6068HF150) Engine - 11Aug14 ( FR DE IT ES SV )
8427 - PowerTech 6.8L (6068HF250) Engine - 12Aug14 ( FR DE IT ES SV )
8428 - PowerTech 6.8L (6068TF120) Engine - 12Aug14 ( FR DE IT ES SV )
8430 - PowerTech 6.8L (6068TF150) Engine - 12Aug14 ( FR DE IT ES SV )
8431 - PowerTech 6.8L (6068TF151) Engine - 15Oct14 ( FR DE IT PT ES )
8432 - PowerTech 6.8L (6068TF220) Engine - 13Aug14 ( FR DE IT ES SV )
8507 - PowerTech 10.5L 6105AF001 Engine - 30Sep14 ( FR DE IT ES SV )
8508 - PowerTech 12.5L 6125HF001 Engine - 16Sep14 ( FR DE IT ES SV )
8509 - PowerTech 12.5L 6125AF001 Engine - 30Sep14 ( FR DE IT ES SV )
8602 - PowerTech 6090HFG94 Gen Set Engine (Interim Tier 4) - 15Oct14
8671 - PowerTech 4.5L OEM (4045 Tier 3 Engine) 4045TF285 - 01Dec14 ( FR DE IT ES SV )
8683 - PowerTech 4.5L 4045TF275 OEM Engine - 14Oct14
8684 - PowerTech 4.5L 4045HF475 OEM Engine - 12Nov14 ( FR DE IT ES SV )
8685 - PowerTech 6.8L 6068TF275 OEM Engine (Saran and Torreon) - 14Oct14 ( FR DE IT ES SV )
8686 - PowerTech 6.8L 6068HF475 OEM Engine - 02Dec14 ( FR DE IT ES SV )
9080 - PowerTech 4.5L 4045HF275 OEM Engine - 23Sep14
9081 - PowerTech 6.8L 6068HF275 OEM Engine - 09Dec14 ( FR DE IT ES SV )
9201 - 6403 Tractor (North American Edition) - 15Dec14
9281 - PowerTech 2.4L (4024) OEM Engine (4024TF220) - 26Aug14 ( FR DE IT ES SV )
9282 - PowerTech 3.0L OEM Engine (5030HF220) - 29Sep14 ( FR DE IT ES SV )
9383 - PowerTech 2.4L (4024) OEM Engine (4024TF270) - 26Aug14 ( FR DE IT ES SV )
9384 - PowerTech 2.4L (4024) OEM Engine (4024TF280) - 27Jun14 ( FR DE IT ES SV )
9385 - PowerTech 3.0L OEM Engine (5030HF270) - 15Oct14 ( FR DE IT ES SV )
9405 - PowerTech 12.5 L 6125AFM75 Marine Engine (ESN 030000- )(Waterloo) - 29Sep14 ( FR DE IT ES SV )
9433 - PowerTech Plus 4.5L 4045HF485 OEM Engine - 20Nov14 ( FR DE IT ES SV )
9436 - PowerTech Plus 6.8L 6068HF485 Tier 3 OEM Engine - 13Oct14 ( FR DE IT ES SV )
9439 - PowerTech Plus 9.0L 6090HF485 OEM (6090 Tier 3 Engine) - 29Sep14 ( FR DE IT ES SV )
9442 - PowerTech 13.5L 6135HF485 OEM Engine - 29Sep14 ( FR DE IT ES SV )
9457 - PowerTech 3.0L OEM Engine (5030TF220) - 14Jul14 ( FR DE IT ES SV )
9573 - PowerTech 6068HF285 OEM (6068 Tier 3 Engine) - 29Sep14 ( FR DE IT PT ES SV )
9574 - PowerTech 4.5L OEM (4045 Tier 3 Engine) 4045HF285 - 29Sep14 ( FR DE IT ES SV )
9672 - PowerTech 3.0L OEM Engine (5030TF270) - 29Sep14 ( FR DE IT ES SV )
9700 - PowerTech E 2.4L OEM Engine (4024HF285) - 29Sep14 ( FR DE IT PT ES SV )
9701 - PowerTech E 3.0L OEM Engine (5030HF285) - 02Oct14
9722 - PowerTech 4.5L OEM Engine (4045HF280) - 30Sep14 ( FR DE IT ES SV )
9723 - PowerTech M 4.5L OEM (4045 Tier 3) 4045TF280 Engine - 07Aug14 ( FR DE IT ES SV )
9727 - PowerTech 9.0L 6090HF475 (Tier 3) OEM Engine - 30Sep14 ( FR DE IT ES SV )
9754 - 13.5L PowerTech 6135HF475 OEM Engine - 13Oct14 ( FR DE IT ES SV )
9757 - PowerTech 2.4L OEM Engine (4024TF281) - 13Oct14 ( FR DE IT PT ES SV )
9758 - PowerTech E 2.4L OEM Engine (4024HF295) - 13Oct14 ( FR DE IT PT ES SV )
9769 - PowerTech 12.5 L 6125SFM75 Marine Engine (ESN 300000- ) - 29Sep14 ( FR DE IT ES SV )
9800 - PowerTech 9.0L OEM Engine (6090HF484) - 20Jul14
10379 - F935 Front Mower - 19Jul14 ( FR DE IT ES SV )
10385 - F932 Front Mowers - 15Mar14
10527 - PowerTech PSX 6.8L 6068HFC95 Diesel OEM Industrial Engine (6068 Interim Tier 4) - 03Dec14 ( FR DE IT ES SV )
10528 - PowerTech PSX 6.8L 6068HFG95 Diesel OEM Generator Set Engine (6068 Interim Tier 4) - 03Dec14 ( FR DE IT ES SV )
10529 - PowerTech PSX 13.5L 6135HFC95 OEM (IT4 Engine) - 03Dec14 ( FR DE IT ES SV )
10530 - PowerTech PSX 13.5L 6135HFG95 OEM (IT4 Engine) - 12Nov14 ( FR DE IT ES SV )
10578 - PowerTech PVX 6.8L 6068HFC94 Diesel OEM Industrial Engine (6068 Interim Tier 4) - 03Dec14 ( FR DE IT ES SV )
10579 - PowerTech PVX 6.8L 6068HFG94 Diesel OEM Generator Set Engine (6068 Interim Tier 4) - 04Dec14 ( FR DE IT ES SV )
10616 - PowerTech 9.0L 6090HFG86 Diesel OEM Generator Set Engine - 12Nov14 ( FR DE IT ES SV )
10709 - PowerTech 13.5L 6135HFG75 Diesel OEM Generator Set Engine - 12Nov14 ( FR DE IT ES SV )
10714 - PowerTech 4.5L 4045TF290 Engine (Worldwide Edition) - 12Nov14 ( FR DE IT ES SV )
10728 - PowerTech PVX 6.8L 6068HFC93 OEM Engine (6068 Interim Tier 4) - 16Oct14 ( FR DE IT ES SV )
10878 - PowerTech PWX 4.5L 4045HFC92 Diesel OEM Industrial Engine (IT4) - 25Nov14 ( FR DE IT ES SV )
10879 - PowerTech PWX 4.5L 4045HFC93 Diesel OEM Industrial OEM Engine (IT4) - 25Nov14 ( FR DE IT ES SV )
10880 - PowerTech PWX 4.5L 4045HFG92 Diesel OEM Genset OEM Engine (IT4) - 13Nov14 ( FR DE IT ES SV )
10881 - PowerTech PWX 4.5L 4045HFG93 Diesel OEM Genset OEM Engine (IT4) - 13Nov14 ( FR DE IT ES SV )
11087 - PowerTech Plus 4.5L 4045HFG85 OEM Engine for Gen Set - 10Dec14
11482 - PowerTech Plus 6.8L 6068HFG85 Gen Set Engine (6068 Tier 3) - 18Nov14 ( FR DE IT PT ES SV )
11600 - W210 Combine (S.N. 010000- )(China Edition, MY14) - 17Nov14 ( ZH )
11602 - C230 Combine (S.N. 010000- )(China Edition, MY14) - 17Nov14 ( ZH )
11603 - Y210 and Y215 Corn Pickers (S.N. 010000- )(China Edition, MY14) - 18Dec14 ( ZH )
11664 - C230 Combine (China Edition) - 16Dec14 ( ZH )
11873 - PowerTech PWX 4.5L 4045HFC95 Diesel OEM Industrial Engine (IT4) - 18Nov14
11958 - PowerTech 9.0L 6090HFC09 Engine - 20Nov14 ( FR DE IT PT ES )
11959 - PowerTech 9.0L 6090HFG09 Engine - 20Nov14 ( FR DE IT PT ES )
11990 - PowerTech 13.5L 6135HFC09 Engine - 16Dec14 ( FR DE IT PT ES )
11991 - PowerTech 13.5L 6135HFG09 Engine - 16Dec14 ( FR DE IT PT ES )
12081 - PowerTech EWX 4.5L 4045TFC03 Diesel OEM Industrial (FT4) Engine - 27Oct14
12082 - PowerTech EWX 4.5L 4045TFG03 Diesel OEM Genset (FT4) Engine - 19Dec14
12184 - PowerTech PVS 6.8L 6068HFC08 (FT4) OEM Engine - 01Dec14 ( FR DE IT PT ES )
12185 - PowerTech PSS 6.8L 6068HFC09 (FT4) OEM Engine - 01Dec14 ( FR DE IT PT ES )
12186 - PowerTech PVS 6.8L 6068HFG08 (FT4) OEM Engine - 01Dec14 ( FR DE IT PT ES )
12187 - PowerTech PSS 6.8L 6068HFG09 (FT4) OEM Engine - 01Dec14 ( FR DE IT PT ES )
12293 - PowerTech 6.8L 6068SFM50 Marine Engine - 21Jul14 ( FR DE IT ES SV )
12297 - PowerTech 4.5L 4045TFM75 Marine Engine - 21Jul14 ( FR DE IT ES SV )
12298 - PowerTech 6.8L 6068TFM75 Marine Engine - 29Jul14 ( FR DE IT ES SV )
12402 - Y110 Corn Picker (S.N. 010000- )(China Edition) - 17Nov14 ( ZH )
12403 - Y115 Corn Picker (S.N. 010000- )(China Edition) - 17Nov14 ( ZH )
12411 - PowerTech PSX 13.5L 6135HFG84 (Tier III) OEM Engine - 18Dec14 ( FR DE IT PT ES )
12432 - PowerTech 2.9L 3029HFG03 Genset (FT4) Engine - 18Dec14 ( FR DE IT PT ES )
12516 - PowerTech 4.5L 4045HFG09 FT4 OEM Engine - 18Dec14 ( FR DE IT PT ES )
12517 - PowerTech 4.5L 4045HFC04 FT4 OEM Engine - 19Dec14 ( FR DE IT PT ES )
12519 - PowerTech 4.5L 4045HFG04 FT4 OEM Engine - 19Dec14 ( FR DE IT PT ES )
Thank you for your reply.
I then wonder why does the Technical Manuals say that in the "start sequence" there is continuity between the G terminal and ground, while there is no wire attached to the ground? - please see the wire diagram from the Technical Manual where I there is no wire connected to the G terminal.
Is there a contradiction in the JD Technical Manual between the wiring diagram (attached) and the description of the "start position"? What would the grounding of G terminal accomplish?
Likely, the "G" terminal is used in some applications for an instrument lamp test feature.
Since nothing is connected to it for your application, I wouldn't think you need to worry about it.
As was mentioned by Bob, the "G" terminal is used as a momentary parallel ground circuit to test some indicator lamps during "cranking", such as the air filter restriction lamp. Unlike the "OIL" and "AMP" lamp circuits which are normally closed when the engine is not running, the air filter lamp vacuum switch is normally open, and is closed only when vacuum in the air intake closes the switch. I did not find that this test circuit was used on the 2240, but it was used on the 2520 and larger Waterloo tractors.
Agri Services
I saw your JD 2040 wiring diagram. I just purchased a 1981 vintage JD 2040 today where the owner had passed away and the son was selling it. The instrument cluster covers were missing therefore someone has probably tampered with the wiring in the instrument cluster. I got it at a really good price because it has multiple "problems". I finally got it started, but it would not cut off with the key. My Case 380CK diesel has a mechanical lever that cuts off the fuel, whereas, this JD 2040 (i assume) has an electric fuel shut off. After searching for several minutes (in the snow and it was dark) for a fuel shut off and removing several wires from the key switch, I finally put it in high gear and popped the clutch to stall it. Before I put this tractor on a trailer, I would like to get a clearer wiring diagram where the key components are actually labeled so I can figure out how to stop the engine once it is on a trailer. Can you assist with a few more wiring diagrams? Once I get it towed back to my house (200 miles away) I will get a full manual from JD. I intend to restore this tractor and put it back in excellent condition.
I have a Case 380CK that I purchased that had the instrument cluster completely disconnected and miswired. I rewired and restored (new gauges, new connectors, disassembled and repaired all switches, new paint) the entire instrument cluster of my Case using the factory manual I have. I have also sent wiring schematics other Case owners around the world that have have asked for my assistance. (See Case 380CK forum) Can you assist with additional wiring diagrams for the JD 2040?
Please PM me if you can assist.
(quoted from post at 04:29:55 02/26/15)
1981 2040 engine is stopped running by pulling out on the kill cable not electronically. Here's the part number RE10597 PUSH PULL CABLE
Thanks Jim, I think the cable is probably broken off and frozen in the "fuel on" position, because it was not anywhere to be found. There was nothing to release or push in to kill the fuel. I just turned the key and it started once I put a battery into it. I looked around the fuel injection pump to see if there was a cable or lever I could move to cut off the fuel, but only saw the throttle cable. The guy I bought from did not know anything about it since it was his fathers. As I said, I knew the tractor had "issues" when I bought it and I knew that once i got it home, I could easily repair any problems it had. I just need to get it on a trailer so that I can give it some much needed TLC.
JDs are new to me. I just need to learn the JD location of everything. Trying to do this in the dark, in the cold and with snow on the ground, didn't help, thus my assumption that this model had an electric fuel shutoff.
