2290 Implement plug
LloydC
Has anyone wired a 7 prone Implement plug to a Case 2290. Are there wires that are available? There is factory hole cut in the lower rear of cab that fits the plug.
We have one that came with the plug installed. Turn signals, brake lights and probably accessory power. Just use the turn signals and brakes for the midsized baler. Shouldn't be too hard to wire one in.
You can buy both the outlet and the wiring harness from your Case dealer. The harness is a little spendy at around $80 if I remember correctly.
My 2290's have the wiring stuck up under the back corner of the cab. You should just be able to pull them out (maybe cut off a zip tie?) and hook them up to the according spot on the plug in you will have to buy. Both of my 2290's are 1979 models.
