2290 spindles
Broke a RH front spindle on my 2290 yesterday moving manure. Called Titan and they didn't have one on stock but could get one for....sit down now..... $1600.00
WOW. I had ordered some from A&I in the past but was having problems with their quality of items lately. Ended up getting a used one from Rock Valley Tractor Parts for $98
Anyone else have any better ideas? Thanks.
On a side note, I also had broke the little eye bolt that screws into the hydraulic valve block that the cable and L shaped brackets fasten to by a clevis pin. One Titan store said they couldn't order it anymore. The other Titan store 20 miles in the opposite direction said they could get it but $52. Also got it from Rock Valley for $10
$1600 for a spindle is nuts!
I don't understand whats happening to the price of parts but its got to stop.
I need a pitman drive pulley for a PT10 Hesston mower conditioner and I cant find one. Its the same as a Case 555
I also need a needle for a 440 IH wire baler. One needle is worth more than what I paid for the baler.
Its nuts!
Yep, just plain goofy on prices of parts! I think they want about $700 for a 90 series muffler. I know a couple yrs ago the 7130 muffler was gonna be like $550, no other pipes just the muffler under the hood. You could try Elmer's Repair in Centralia KS for the spindles.
Brad
The pulley I need is the one that drives the pitman arm. It has a stub shaft that the pitman shaft sets on that drives the sickle..
It might be the same I do know. A PT 10 and PT 7 are the same but i will try to find out about a 1091 hesston
(quoted from post at 14:46:55 03/12/16) Needed brake disc for a 1070, CASE wants $144 ea, A+I wants less than $30. Rod.
I do it too, but doesn't it feel wrong putting JD parts into a Case?
