2290 won't move
806Jr
Hey guys, I have a friend that has a 2290 that won't move in
reverse or 1st and 2nd forward(doesn't matter what range the
power shift is in)when it gets down below zero and the
hydraulics won't work and the transmission oil light stays on, if
you put it in 3 or 4th gear it will move. Now that it has warmed
up he went to pull it out of the shed and everything works
again. The oil is on the full mark. We are wondering what to
start checking to figure it out. Any ideas would be appreciated.
Thanks, DuWayne
You might want to try to let the tractor sit for a while and then drain some oil out of the tranny and see if there is water at first , it may have ice blocking the flow to the pump
