2294 gear pump?
Eddie7295
Got the 2294 out and let it warm up got 50 psi at full throttle in first and third power shift 40 psi in second when idled down they all fell to nothing on the gauge thinking the small gear pump is bad got 2200lbs at the remote at idle. What would be the correct lube pressure at hot idle for that tractor.
To the best of my knowledge there is no spec for lube pressure on a 94 series. If gear pump was bad you would have weak/no power steering or low pressure w/gauge teed into steering line and wheels cramped.
