casemagnum
I have a 2294 i just bought. Came home the other night went to put into park and wouldn't go in completely. Tried to put back into gear but wouldn't go into a gear. Shut off tractor. started back up and went into gear but will not move forward or backward. Inching pedal is dumping oil when you push it in. Solenoids on right side are engaging correctly. You can hear the power shift shift when you move it. Will not go into 3rd gear on transmission side yet though. Still have power steering and brakes and pto and hydraulics. Wondering what eveyone thinks?? I am thinking either torque limiter(s), input shaft, output shaft on power shift, or pinion shaft for not moving but still does not explain not being able to shift transmission into 3rd. ANY SUGGESTIONS????
