2320 john deere loader
bumblebee
Can anyone explain what is the best way to take a loader off the 2320? Is there a simple
way to lift the back of the loader that rests in the loader bracket? I have a manual, but it says nothing. Thanks for your suggestions.
There are several videos on youtube that show much better than I can explain. It's pretty simple though. You lower the loader on the ground till the front wheels come off the ground. There are latches on the loader masts that you lift up with your foot on each side. Once unlatched you work the lever the opposite way and the front stand will come down on the ground lifting the loader off the tractor. You lift it off till the tractor can clear the loader good then shut the tractor off. It is important that you work the joystick around good with the tractor shut off to relive the hydro pressure. Once that is done you can unhook the hoses which should be color coded and then start tractor and back away.
Maybe you just have the tractor manual ? You will also need the manual on the loader attachment and it should be full of info.
once the locks are lifted on the loader attachment points I usually use the hydraulics to lift and push the loader up and away from the tractor. I then back up a few inches and do as was previously stated when disconnecting the lines. Very easy and can be done extremely fast once you get the hang of it.
Here is a very good video on taking your loader off.
Basically push down with your loader. Lift the front axle just a little bit. Unlatch the boom latches on each side. Then slowly "lift" the loader while backing up. This put the loader mount/parking stand down. It will lift the rear of the loader off the mounting . The shut the tractor off and work the joystick to dump the pressure off and then disconnect the hoses and back away.
John Deere 2320 loader removal
