235 Massey Ferguson
Lyons2007
I have a Massey 235 with a Perkins 3 cyl.
There is a low pressure fuel line coming ffrI'm the top of the fuel tank to the fuel pump. The ferrel has broken that connect to the pump and is leaking awful. I have checked everywhere for a replacement amd no one seems to know what it is or where to find it. Help!!
You are referring to the line that goes from the top of the fuel tank to the fuel filter. Part number 531367M93 is for tractors after serial number 9A228058. Part number
531367M92 is for tractors before serial number 9A228058.
When mine broke years ago it was replaced with a rubber fuel line. It hasn't leaked since. Something to think about if the tube below is hard to find.
You can also measure the outside diameter of the line then make a new line out of new metal brake line like you would find at you local auto parts store. You still need the new sleeves, or olives as they are called if you make a new metal line.
