2350 loader on a 544?
Fullern90
I want to know if a 2350 loader will work on a 544 row crop or
if a 2001 loader is the only one it will accommodate? Thanks -
Neil
I don't think you would want a 2350 loader on a 544. The 2350 was made for the 66 series tractors which were considerably larger. The 2001 or the 2250 would be better choices for a 544. Hope this helps. Kent
A 2350 will fit. It's a heavy loader for that tractor but it will fit just fine.
The frame rails are 2" closer together than a 66 series so you'll need 1" of spacers on each side. Also, need some holes drilled in the frame for the rear brackets.
