2355 wireing question
730-LP
I have a 2355 with a cab and need to put a air cond. themostat in.It has the wrong one in it and has 4 post to put wires on but only two wires. the orginal only has two post.Which wire goes where one is yellow? and the other blue? or does it matter don'want to blow a $50.00 thermostat any help would be appreciate Thanks
Best thing is to see a wiring diagram so as to be absolutely sure. I have a 2350 without cab, and the wiring can get complicated, especially with a cab. The money for a Deere factory service manual which has the wiring diagrams is well spent.
I agree that a manual will be helpful!!
In the meantime I'll tell you what I know and you will have to decide for yourself if it applies to you.
My experience with those switches is that they are not thermostats at all, but rather they are potentiometers that control the level of flow through the heater core by opening and closing a valve (electronically). So the the potentiometer exerts different levels of resistance (if resistance could be exerted)to controll the motor that opens and closes the heater valve (like a fuel sender operates the guage).
In my experience potentiometers they are farily forgiving of abuse. If you hook it up backwards it will either work or it wont. If it does not work then hook it up the other way. Some will even work regardless of how they are wired, as all it has to do is create various levels of reisitance in accordance with where the knob is turned.
This is my experience with modern day climate control swithches in John Deere equipment. Yours may be all together different, as a 2355 could be up to almost 20 years old now (getting a little older).
If in fact this does not apply to your application then you can say at least you learned something about climate control switches in modern equipment.
730-LP, I just happened to think you may be talking about the thermostatic switch in the evaporator core. If that is the case it should'nt matter which wire you put where. The switch is either open or closed allowing current to pass to the compressor relay when closed (when the evap core is warm enough to allow the compressor on).
Please forgive my earlier post if this is what you were looking for.
