2394 flasher relay?
ih66
Was wondering if anyone could tell me where the flasher relay is located on a case 2394. Had all the lights working 2 days ago. Yesterday when I went to use the tractor the front head lights worked, red tail lights worked & the yellow flasher lights lite up when you use the turn signal but the flashers don't work. I checked the fuses and they seem to be good. If the flasher relay is behind the gauge cluster which one is it. Thanks for any replys,
Check power on both sides of the fuse. If they are both dead the relays are under the dash on the right side clear up on top. You will need to remove the dash unit to get in there. I have a terrible time with the connections to the relays, and all the fuses on my 2394. Never had a single problem with the 30, 70, or 90 series tractors.
Your flasher unit is the turn signal switch. I looked on the cnhi parts , if that will help. I replaced mine in the 2390 I had. Jerry from Ohio
