Despite all the fun 24 volt chat below, (fun for us sparkies even if others were bored to tears) I didnt see this issue raised so here goes. I had a good supper (fish fry n beer at American Legion Hall then Dairy Queen) and now all rested lol ready to go back to work..
When giving workshops or seminars or when in the tractor business I often got the question: "I have a 24 volt Deere and one of the batteries keeps going down yet other one doesnt hmmmmmmmmmmm whats wrong"
I tell them one among many possibilities (if all else and batteries are okay) IS DUE TO THE STARTER
Then they say "But I thought the starter was a 2 terminal 24 volt ELECTRICALLY ISOLATED FROM FRAME GROUND DEVICE" To which I respond "YES it is weedhopper but heres a scenario under which a starter problem can cause one battery to discharge.
Its possible soft copper dust from the brushes has accumulated to a point that theres an internal shorting electrical conductive path through the copper dust from the internal connector to frame ground AND IF THAT HAPPENS ONE BATTERY CAN TRICKLE DISCHARGE
That can still happen DESPITE THE FACT the starter isnt supposed to have any electrical connection to frame ground AND HERES HOW N WHY
On the 24 volt starter (unlike a 12 volt with only one stud and case ground serves as the other) there are 2 big post/studs, one to the + grounded battery and the other to the - grounded battery (remember where the batteries join in the center thats also bonded to frame ground via a small jumper wire) so theres 24 volts to the starter once the solenoid closes.
Nowwwwwwwww imagine inside copper dust (off brushes) has accumulated so theres a shorting path from one of the internal post connections to the steel frame portion of the starter THAT CAN CAUSE A BATTERY TO DISCHARGE becauseeeeeeee the other post of that battery is also tied to frame ground at that center tie point
Sooooooooo if the starter has some age on it and one of the batteries is discharging and all else is okay, CHECK THE STARTER FOR A COPPER BRUSH DUST SHORTING PATH
Hope this helps, best wishes n God Bless yall and thanks to all who helped in this neat discussion, hopefully we helped answer some questions
Ol John T and all
Ol John T and all
