240 utility clutch question
Recently bought a 240 utility, the clutch was not letting go, and when you forced it to stop by using the brakes, it made an awful grinding noise. I replaced the clutch, and TO bearing, and it still does the same thing... almost like its not letting go properly. Ive adjusted the throw on the pedal all the way both ways little by littel and it still does the same thing.
any ideas?
Did you change the pilot bearing in the flywheel? Did you adjust the clutch brake to much, or in the wrong sequence, so it is dragging to hard if it has one. Is the throw out bearing new and did you grease it. Are the splines clean and lightly greased/oiled.
I have an IH 240 Utility,, seems I have to change the clutch and TO Bearing every year or so,, found that I have to Grease the TO Bearing and parts that move, and make sure the fingers are adjusted on the clutch.
I did not replace the pilot bushing... it looked to be pretty good, so i skipped it, i have a new one, probably should have done it but did not. The clutch brake im not sure about. i did greast the new throwout bearing.
