Tyler Sperry
Hello everyone. I'm still working on getting our Massey back into working order. It finally runs, but aside from a few new leaks, the electrical system seems to be doing some weird stuff. I am no expert in electrical. I know some basics but not really enough to get any useful diagnostics on the problem.
Anyways, I had been reading up on some forms and scouring the diagrams as to why the tractor is doing what its doing. I had seen on some of the forum discussions that there is a oil pressure switch somewhere that energizes the gauges? If so where is that located? As it seems that could be my problem? If not what should I check, and what should I check for?
Currently I get a oil pressure reading and a tachometer reading just fine since they are both mechanical. My work and head lights seem to work just fine. The gauge lights don't but I suspect my grandpa never changed those bulbs lol. The Amp/voltage meter only shows a drop when I hit the key to start the tractor then its back to neutral. Doesn't show a charge or anything. And I'm not entirely convinced the alternator is putting out enough power to charge the battery at the very least. I also am not getting any readings from the fuel or temperature gauge. Id really like to have the temperature gauge back at the very least. I have the hood off at the moment, so if I need to replace the fuel sender not a big deal. But if it works, I don't want to have to replace that if I don't have to. Same with the thermostat.
I have replaced the battery and the battery leads since both were not only old, but not making good contact and were beyond heavily corroded. With those the tractor does start far better than it had, no longer requiring a jump pack or jumper cables.
Any advice would be greatly appreciated!
