2510 gas tractor ?
swindave
in my area 3020 gas tractors have a very poor reputation,
but i know nothing about 2510 gas tractors!
what's the good, bad and ugly of a 2510 gas, synchro, 1967,
shows around 5000 hours on tack, tractor looks good overall,
thank you
The carbs were totally different and the 2510 works much better than the 3020 on todays gas. The 3020 used a very heavy balancer system with 2 gears that ran off the crankshaft that makes them a little sluggish in throttle response. The 2510 used a different setup that makes them snappier to operate. The bad is 2 issues. The pto setup is not as good as the 3020's and when new they had a 4 piston hyd. pump. The 4 piston pump is ok when working but if it ever fails you are much better off updating to 8 piston pump like the 3020-4020. For a small tractor they handle great. I have both a 2510 gas and a diesel. Tom
