255 Fergie engine CID location????
Hi there... I have a 1976 Massey Ferguson 255 and I would like to know what displacement the engine is.... It is a Perkins diesel that much I do know.
WHERE are the numbers located??????
Thanks...
Great web site!
Hi, You could have either the A4-203 (203 cu.in), or the A4-236 (236 cu.in.). Both were used. email me direct and I'll send you a data sheet for the numbers/locations.
Regards ... chas
most of the perkins engines i've seen had that info on the inlet manifold on a small plate, the later ones like the 300 series had a small plate fixed to the gngine block.hope this helps.
