I've got something causing power steering pumps to fail in less than 100 hours. They start leaking out the front seal into the engine oil. This is the pump with an internal reservoir that is plugged with an O-Ring plug.
I think it's building pressure inside the pump forcing the oil out. I don't see any design to relieve any pressure from heat, just the air space in the upper half of the reservoir.
I discussed this with my local MF dealer service, they seemed less than anxious to work on it. They suggested plumbing in an overflow tank or remote reservoir by converting the plug to ORB fitting.
Any thoughts? It's too good of a tractor to give up on a fix
