Guys need some help. Got a 2550 that seems to be starving the main hydraulic pump. I?m not a big fan of the little German tractors myself, but we?ve had this one several years and it?s been good for what it was good for. I don?t have a book yet and was looking for pointers on the famous internal leaks that those tractors were prone to. The front pump has less than 100 hrs on it. Long story on that and it ended up an engine rebuild when the little chip off the crankshaft pulley went through the timing gears. Last fall it started this cavitation thing and I?m wanting to get to the bottom of it before we start pulling the twin rake with it again. It always had plenty of flow and stayed cool enough to do the job. At the end of the season last year we ended up using a different tractor because the hydraulic temp was running higher than I was comfortable with. If it was a row crop tractor I would say that the transmission pump is weak and isn?t supplying enough oil to run any through the oil cooler. So I?m open to ideas. Also this tractor does not have a hi/lo
