2590 3rd remote
pretty easy as long as you have all the parts, all you need is the valve, the handle to run it and the cable that runs to the valve from it, and hoses to run to the back of the tractor, unbolt your valve "stack" add the third valve run longer bolts thru it to hold it all together and your good to go. Any salvage yard should be able to set you up with the parts you need.
As Loren says they are stacked or sandwiched together, basically oil flows from one to the next to the next until it passes through all of them and then flows out the return and back into the system. Hypothetically speaking you could have an infinite number of valves stacked together and they would all be fed by the initial inflow from the pump. Take a look at the link to the parts manual and I think you will understand what I mean, the link goes to the Two section one like you have, you would just be adding one more of the valves to the middle.
Untitled URL Link
