2600 gas gauge
John (TR)
Anyone know what the ohm range is on the stock sending unit for a 2600? I'm working on a new dash, checked this sending unit with the ohm meter and was surprised to see that it might actually be working. It read around 80 ohms with a partial tank of gas. There are several ranges of resistance that work with the gauges I'm buying (Auto Meter)and I have room for 1 more gauge. I realize I can figure it out by filling/draining the tank but thought I would check to see if someone knows.
John
If you do not want to pull the float assembly out of the tank. A coat hanger stuck down through the fill hole could grab the float also. Then you can lift and push to go through the full range.
I know I used a sending unit from my 7000 row crop in my 1964 ford 4000 with a Sunpro gauge. It works GREAT. I had to cut the verticle support and bend the float arm, but mine reads full at full and empty just before empty (The 7000's tank is a lot taller than a 4000 4 cyl tank).
By the way I believe at least one of the sending units had a Stewart - Warner tag on it.
