2630 hydraulics
R Bruce
I'm looking for info to install belly remote outlets on my 2630 for my loader. I've plumbed from the back for years, but I want to put it mid belly to get rid of the long hoses and free up that remote.
thanks in advance for help!
Although the photo below is for older JD utility tractor that doesn't have priority valve the principle is the same. The top hose supplies pressure to remote valve & bottom hose connected to ported filter cover is for return oil from control valve. Be sure any added valve is setup for closed-center hyd's. Cheaper ported filter cover from JD is part # L55982 @ $108
This post was edited by Tx Jim on 03/08/2022 at 09:45 am.
Just to add to good info Tx Jim stated: Make sure the tee for pressure line is passed priority valve , on 2630; on line going to rear remotes & rockshaft.. Some good pics & info in 145 loader manual ; You can download on jd techpubs , just google it...
(quoted from post at 19:47:24 03/08/22) Just to add to good info Tx Jim stated: Make sure the tee for pressure line is passed priority valve , on 2630; on line going to rear remotes & rockshaft.. Some good pics & info in 145 loader manual ; You can download on jd techpubs , just google it...
Thank you!
