(quoted from post at 19:17:10 07/20/19) If it was the oil cooler would it not also have water in the oil
Not necessarily.
The oil side is under a lot more pressure.
In addition to the "core" leaking, there's an O-ring or two involved.
It's certainly the first thing I'd check.
Went through the same scenario a while back with an 855 Cummins, the radiator overflow was puking oil slime, and not a drop of coolant in the "basement".
Replaced the cooler "core" and all is well.
Not necessarily.
As long as it was holding compression there would be no other symptoms.
I'm not sure how the oil is delivered to the rockers, some have a metered flow, so very little pressure actually make it to the head. But if it has full pressure, it can leak oil only into the cooling system, or outside the head, or both.
