I was pushing brush into a pile in a hollow. I moved the reverser to reverse and nothing happened. Failure was immediate. Was in 1st gear. No unusual noise, vibration, etc. Nose of tractor was down on a fairly steep incline (not dangerously steep). I had to use my 'G' to pull it to level ground. Trans oil level was good.
It's a '79 model with reverser. About 7800 hrs on working tach. Two shift levers. Has a 148 loader. Hydraulics work as always and 3pt with 8' blade raise normally. I can only engage PTO with clutch depressed. Clutch seems the same as always. I can move both shift levers to any position without using the clutch. There is a very slight grinding at first with the left lever but just for a moment. The reverser makes no difference in either position.
I was just wondering if any of you have experienced this problem and where I should start looking. I have not removed the transmission covers yet.
