265 hydraulics
Steve265
This message is a reply to an archived post by MF1 on October 16, 2011 at 13:21:18.
The original subject was "Re: 245 hydraulics".
My father has a 265 and purchased a loader for it before he passed away. I have mounted the loader and currently run the hydraulics off of the rear axillary ports. Is there another way of doing this so I can still use the rear connections for the rear attachments
yes the simplest way is to locate a remote valve off another tractor of the same make that has 2 remotes, i have seen a couple of advertisements for an electric operated diverter valve that plugs into a single remote to make it able to be used for 2 or 3 remotes wasn't cheap though, if you can't locate a valve setup re-post and i will give a couple of alternatives
