275 baler pick up cam
wels
275 with super sweep
On my last bale of the year, my pick up jammed.
From what I can see, I believe, the small radius on the pickup cam is warn through.
Outside of age, would something else cause this?
I was thinking of welding in a patch, any thoughts?
Thanks in advance.
On my 276, I was running it with several cam rollers broken, which slowly destroyed the cam. I bought a new cam from Messicks about
$250. It was really a challenge to install (for an old guy with a bad back).
Simply Age can cover alot of things, so yes, the twine bars rotating a few million times could wear a hole. also, what condition were your twine bar cam bearing
in? If they were frozen or shot that would certainly accelerate the wear. If you do weld the patch in there I would replace the bearings.
(quoted from post at 21:51:24 09/27/21) 275 with super sweep
Thanks in advance.
I think from what I read elsewhere, pulling the pickup head is the best way to go. Then check everything while it is out.
What is the easiest way to pull the pick up head?
I guess I pull the right side wheel, undo the chain. Then one pivot point on each side? Or does the left side sprocket and such come off too?
