2750 Wiring Diagram
JD5210
I am in need of a JD 2750 wiring diagram and/or starting diagram. My neighbor cannot get his to turn over. We have tested the 1 safety switch and it is good.
Thanks in advance for the help.
Wiring diagrams are NICE to have, but are gonna typically cost some $$$ for a DEERE, as they are known to protect their intellectual property rights.
Even without a diagram, you can verify there's battery power to the "ignition" switch" and power leaving the switch on it's way to the safety switch when in "start" position.
You've found the safety neutral start switch, so verify if power's getting there, and passing through the switch on it's way to the starter solenoid, then verify whether or not the power is getting to the starter solenoid.
Grab a unpowered test light and check out where the power is getting "lost", and post back!
