2755 load control shaft seals
Just wondering if it might be a simple job(or not) to replace the bushings/seals on the load control shaft? My I&T manual doesn't elaborate on the process, only mentions it in passing while describing the procedure to R&R the entire sensing system. Here's hoping that's not a requirement to get to the seals. Have yet to locate the shaft or the bushings/seals in the Deere parts book, so not much to go on so far.
Parts schematics is listed under "load control parts". Put L/D control lever under seat in "min". Drain hyd oil. Remove draft links and slide shaft out of trans case. Inspect shaft & bushings for wear & replace if needed. R&R seals,oil shaft and install,replace draft arms shimming greatest majority of shaft side motion out. Before installing oil this would be an excellent time to check sump screen if it hasn't been checked lately
