I have a 2640 with the 276 engine. I am looking for a new block and found one. For those of you in the know, are all the 276 blocks the same? I would think so, but I'm just trying to be sure before I buy it.
(quoted from post at 12:03:01 06/28/16) I have a 2640 with the 276 engine. I am looking for a new block and found one. For those of you in the know, are all the 276 blocks the same? I would think so, but I'm just trying to be sure before I buy it.
Free parts book on the JD web site tells all.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Apparently these are the only applications that block was factory installed in.
1401 - 2630 Tractor - 16May11
1539 - 2640 (s.n.-340,999) Tractor - 16May11
1761 - 2640 (s.n. 341,000- ) Tractor - 16May11
2312 - 540E, 640E, 740E Skidders and 548E, 648E, 748E Grapple Skidders - 07Apr16
CYLINDER BLOCK
Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS
1A AT13740 DRAIN VALVE 1
1B R55233 PIPE PLUG 1
2 15H624 PIPE PLUG 1 1/2"
3 R39741 DRAIN PLUG 1
4 U13639 O-RING 1
5 12H304 LOCK WASHER 3 3/8"
6 14H812 NUT 3 3/8"
7 T18891 PLUG 2
8 R26650 DOWEL PIN 2
9 T33279 STUD 2
T25701 STUD 1
10 R26241 DOWEL PIN 2
11 R48685 DOWEL PIN 2
12 AR97774 CYLINDER BLOCK 1 (MARKED R73657, R78556 OR R60832) (SUB FOR AR73805) (SUB RE13517, (18) R85363 AND R92425)
13 R54802 ORIFICE 4
14 15H690 PIPE PLUG 1 3/4"
If one utilizes the sub part number that b&d posted it broadens the search horizon.
Thanks.......this is helpful. I have the early serial number (before 340,999).
Next Question: From what I got on the JD parts page, they list two cylinder blocks:
AR73805: (MARKED R60832) (SUB RE50671, (8) R85363 AND R125863)
AR97774: (MARKED R73657, R78556 OR R90170) (SUB RE50671, (8) R85363 AND R125863)
I'll have to go check my block's number. But if the block I found is the different one of the two, any guess as to whether it would still work? What would the differences be between them?
