27v hook up help
brian1855
I"m trying to hook up a 27v sickle mower to a
Super C. Can the cutter bar be raised/lowered with
touch control rocker. If so does anyone have photo,
picture, or drawing of set up. Thanks for help.
Brian
If you get hold of a parts book there are some parts shown for a cable lift for the C tractor. Yes, it can be done but you are probably going to have to build your own parts.
Simi mounted draw bar mowers have no problem using the rockers to provide lift. A 3/8" cable is used to provide pulling force on the lever. pulleys are used to direct the force so that it is directed from drawbar level to the lever. The lever action might be dangerous to the operator such that cutting or modifying the lever, or replacing it with shorter flat stock to preserve the original might be wise. The pulley/s should have a fair lead so that the cable is constrained to the groove. More than one pulley might be needed. loops for the ends of the cable should have protection, see link. Good luck, and do not use a solid link, it would lift and drop with trailing tire motion. Jim
Thimble
Ours doesn't have a trailing wheel. It mounts on brackets bolted on the axle housings. A long solid rod from the touch control to a lift link on the mower provides sickle bar lift.I'll try to get a pic later today. If it turns out, I'll send it along.
Photos of 27V mower
