WE HAD OUR 27V IH MOWER MOUNTED ON A FARMALL MODEL M. WE CUT HAY AND MOWED THE SHOULDER OF THE ROAD IN 4TH GEAR. YOU HAVE TO KEEP YOUR GROUND
SPEED FAST ENOUGH TO KNOCK THE CUT MATERIAL OFF THE BAR. TOO SLOW AND IT WILL PLUG. WE ALWAYS USED SERRATED SICKLE SECTIONS AND LEDGER PLATES.
ALWAYS BUILT OUR OWN SICKLES AND REPLACED OUR OWN LEDGER PLATES. THE WERE SMOOTH SICKLE SECTIONS AVAILABLE BUT DAD ALWAYS SAID THE SERRATED
WERE BETTER. THE 7 FOOT SICKLE BAR COULD ALSO BE 'tipped' UP OR DOWN FROM THE HORIZONTAL WE KEPT OURS TIPPED BACK 'up' TO KEEP FROM CUTTING IN
TO GOPHER MOUNDS SO BAD. NOT A GOOD IDEA TO CUT WITH WET OR MUDDY GOPHER MOUNDS AS THIS WOULD CLOG BETWEEN THE LEDGERPLATES. WHEN WE GOT DONE
WE STUCK THE SICKLE BAR IN THE POND AND RAN IT FOR A WHILE. THAT WOULD HELP CLEAD THE DIRT OUT FROM THE BOTTOM OF THE LEDGER PLATES. LPTS OF
MEMORIES!
Sometimes old fogeys with arthritic fingers have trouble using the shift keys so they use caps lock. My wife is one of them. If it's too loud, you could use ear muffs :)
Th farmer that I worked for as a kid always cut pretty fast with his sickle bar, but then he was cutting more mature grass than what we cut these days.
