riverunner
Update! I posted awhile ago about my 2870 starting then it would just die,I would have to run the starter way to long then it would start to sputter then run fine. Fuel was bleeding back to the tank.I had a couple of responses as to what was wrong along with how it could be fixed. I stumbled upon the problem. I was using the hand primer when it would't sart one time and noticed fuel dripping out of the fuel pressure switch,did not leak otherwise. Replaced switch problem solved. Thank you
