2900G engine into 190xt
joeysmith
Tractor was gas an had a piston come apart breaking a liner.
Set long enough the 2800 gasser that was in it its now a boat anchor.
I started this project a few years ago an just kina getting back to it.
The combine oil cooler am filter setup has interference issues in the tractor.
Anyone's opinions on just running the filter an housing off the 2800 gas engine?
Its just a 1 filter setup vs 2 the combine had.
Tractor wont see much heavy work and if it does it'll be running a 14ft swather or 535jd baler for a few hours
Doubt it ever sees a plow again in its life unless its just piddling around.
Any other issues ill run into with the swap?
What age and model combine did this combine engine come from?? Usually combine engines have no provision for a hydraulic pump on the left front corner ?? and you have no parts from your old gas engine to convert the combine engine to a hydraulic pump drive. I don't see what your oil filter issue is?? the filters clear the side frames ?? or does this engine have a coolant tube that goes across the rear of the engine ??
Yes the combine engine has the big wrap around oil cooler with the 2 filter setup.
The filters hit the frame and the back tube hits the clutch arm.
I machined out the front cover to accept the hydraulic pump.
I do still have the gas engine an parts of which the oil filter housing will fit the diesel but its just 1 filter an no cooler.
The combine engine plate
