292 cooling fan
notjustair
I?m in need of a cooling fan that will fit my 64 Ford F600 with the 292 Y block. It?s got a pretty small bolt pattern to it (like 1.25 side to side and 1.75 diagonal or so), so I?m not sure what car fans of the era would fit it. A new one seems to be a strike out from what I?ve found. I?d rather replace the fan than go through the hassle of fitting an electric can with a thermoswitch, but the fire truck conversion when it was new caused the original Ford fan to be tossed.
Anyone know what fans of the era would cross?
(quoted from post at 19:55:02 12/22/19) I?m in need of a cooling fan that will fit my 64 Ford F600 with the 292 Y block. It?s got a pretty small bolt pattern to it (like 1.25 side to side and 1.75 diagonal or so), so I?m not sure what car fans of the era would fit it. A new one seems to be a strike out from what I?ve found. I?d rather replace the fan than go through the hassle of fitting an electric can with a thermoswitch, but the fire truck conversion when it was new caused the original Ford fan to be tossed.
Any of the on-line "speed shops" will have universal fans that will fit, Jegs, Summit, etc., etc..
And here's an outfit that specializes in old Fords, GOOD folks to deal with.
https://www.speedwaymotors.com/shop/cooling-fans~14-4-132-11546
