2950 damper and crank
Pult Eater
Does anyone know if it matters if I rig a jig and cut a new keyway in the crank to replace a ratched one. Does the keyway where it's at balance the crank with the damper pulley?
i would agree that if you put it at 180 degrees and fill the old keyway you should be good. but why take the chance, it is a common crankshaft that can be found. i would repace it myself. crank should be the same as a 329 engine.
