2955 load control shaft and seals
Going to replace the load control shaft and seals in a 2955 cab tractor. Anything special I need to know? I know that some JD tractors need the L/D lever put in a certain place before disassembly. Is this one like that Is anything going to fall out of place inside the rear end? I was raised up on red so this is new to me. Any help would be appreciated>
Yes put L/D lever in "D" or "min" which ever is appropriate for your tractor because this allows pin(item 22) the least amount of contact with L/D shaft. 2955 L/D seal seating area is different being a bolted on flange from smaller JD utility tractors of same era.
