2955 loader
RGnTN
I am putting front loader with joystick on 2955, could anyone tell me where to connect presure and return lines without useing remotes? thanks
(quoted from post at 22:44:39 11/11/09) I am putting front loader with joystick on 2955, could anyone tell me where to connect pressure and return lines without using remotes? thanks
Supply oil requires a "T" in the line that supplies the rockshaft and scv valve(s).
Item #10 for the return oil to prevent the front pump from running dry.
You will never regret using the direct supply and return. In particular with a Dubuque or Mannheim tractor.
1 R34733 WASHER 1
2 AR75603 FILTER ELEMENT 1
3 R32507 SNAP RING 1
4 L29251 RETAINER 1
5 R394R O-RING 2
6 24H1227 WASHER 1 17/32" X 13/16" X 0.060"
7 L29252 COMPRESSION SPRING 1
8 L29250 COVER 1
9 L29253 SCREW 1
10 L55982 COVER 1 (SUB FOR T31170)
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
11 U12547 O-RING 1 (SUB FOR F3171R APPL)
12 R27175 DRAIN PLUG 1 1-1/16"
On 2955 under the right side of the cab on the side of the scv valves there is a plug to remove this is a good connection for your presure line no need to put a T in a line but you will want a ported filter cover for this tractor for the return. This plug is alot easier then putting a T in a line . If you were to add another scv this plug would supply it .You won"t get any more flow by putting a T in the rockshaft line .
connected pressure line to plug on scv valves and return to ported filter cover,easy to do and loader works good. Thanks for your help
(quoted from post at 23:27:07 11/19/09) connected pressure line to plug on scv valves and return to ported filter cover,easy to do and loader works good. Thanks for your help
Thanks for the followup and glad the system works.
