2N barn find
BryGuy
Working on an original 2N (1942). The wiring is original and toasted. Planning on installing a new harness with soldered terminal ends (by me) and new plug wires. Rebuilding the front mount distributor with a spare I have from a '48 8n. Planning on all Standard stuff and a Niehoff coil that came from an estate sale part number FF-177.
Battery cables are embarrassing.
I have been soaking the cylinders with Kroil and a tad of kerosene. This week i'll add some 10W-30 and just cycle it a few times by hand to get the go juice working the rings.
I have a rebuilt TSX-33 to put on it. It has a greasy and stuck TSX-264 (cockshutt?) right now.
Welcome to the forum.
Where in central, MN?
I live in the Cities but my hometown is Aitkin. Was up there deer hunting last weekend. Took a doe. We'll be back this weekend - couple more tags to fill.
Brainerd area. Did some hunting up that way the last few years and only saw turkeys. Didn't see much in the back of trucks coming down highway 10 either.
I tried posting some pictures but I might be on double secret probation until I have more postings. Spam deterrent ?
If the previous owner used 10-30 oil your good to go. If you dont know what kind of oil had been used in the past I suggest you drop the pan and clean out the sludge before you add 10-30 JMHO. Also you may need to prime the oil pump.Check your manual there is a plug on the l/f of the block where you can prime it.
Im just squirting the oil down the cylinders for now, and working it with kroil. I already changed the oil and it didnt look like melted tootsie rolls so my plan is to drain it after Im done turning it by hand, put in 15w-40, and crank it with the starter without plugs in it.
Might get frisky and add a little MMO
I have some cheapy filters to burn up before I use the good stuff.
Already had the hood off when I remembered I needed photos.
Pulled a new wiring harness and new plug wires. Old braided tip up line worked well. Left a chunk of old wire attached so I didnt have a string back out into the conduit. All the bushings in the conduit were still in place.
As you can see the wiring was a little decrepit. Added a new ballast resistor as the original read about 7 M ohms. Of course the holes didnt match up. (AFTERMARKET). After it was all together and still snowing, had nice 1/4 spark that had a good color and snap. The starter is a POS black aftermarket thing. I am sending the original in for a rebuild and bolting on 2/0 welding cables in place of the junk that's there for the starter and battery.
Hooked up a 1 gallon gas tank from a snowblower and ran a line to the freshly rebuilt TSX 33. The battery cables are 2/0, crimped on both ends with shrink tube. Oil and coolant level was good.
Hit the button and it took off with a tiny bit of choke after about 3 seconds of cranking. Ran great. Added some sea foam to the gas tank and some MMO to the oil and varied the RPM's has a had a victory beer. Watched the oil pressure and at idle it was 20lbs. Max was about 30lb. Pretty sweet unit for being 80 years old.
