2N brake cleaning a seal replacement
I have looked at older post on this subject (2016) and the links do not work. I can pretty much figure out the drum brakes but its the seal I have issues with. It just started leaking on the right side and its leaking pretty bad. Any videos or diagrams out there to show how to replace these as I have found none. Second of all what is this sure seal that everyone is talking about is it an actual seal or some kind of stop leak? Does any one know where I can download a service manual for this tractor as I think it would help me a lot. Lots of questions hope you all can help.
Mike
You should ask this in the <a href="http://www.yesterdaystractors.com/nboard/wwwboard1.html">N forum</a>, will get more answers there.
A sure seal is a cup like thing with a seal in it. You need to pack the bearing with grease before installing one as it will no longer be lubricated by oil from the axle housing.
Do a web search for "1953 I&T FO-4 Ford Tractor Service Manual.pdf". You will find it on the other N tractor forum as a free download, cannot put a direct link to it here.
